Afico 3245C with dark shaded background on entire sheet
  • axyun
    • Aug 2007
    • 1323
    Changed color brushless motor today the motor turned and motor code was eliminated. Had new code of SC685 attributed to scanner connection whic is ok now. However, prints image but have dark shaded background on entire sheet. Your help is greatly appreciated. Stillin customer's office. Frank
  • COPIERMAN
    • Jun 2009
    • 559
    Re: Afico 3245C with dark shaded background on entire sheet
    sounds like you lost drum corona charge. check all your connections that you took lose make sure they are seated properly.
    • axyun
      • Aug 2007
      • 1323
      Machine prints normally from computer or when I print counter sheet from control panel .
        • 37357
        SBU or IPU.
        • Iowatech
          Not a service manager
          • 3930
          So prints are OK, but copies are not? If the copies were OK before this, it might not hurt to review the scanner connections. The SBU connections are where I'd start, then maybe the scan lamp.
          Might need to clean the optics if you aren't sure about copy quality. Based on that error code I'd also check to see if something was blocking the light from the scanner from getting to the SBU.
          • axyun
            • Aug 2007
            • 1323
            Thank you. Will recheck connections etc. Customer considering another machine as well.
            • COPIERMAN
              • Jun 2009
              • 559
              if prints ok and counter report is ok then optics is problem. check lamp does it come on then check mirrors they could be out of position they have a clip holds in place maybe fell out or mirror shifted, or optics were caught and cable move try follow opitcs alignment in service manual.
              • axyun
                • Aug 2007
                • 1323
                thanks copierman
