Ricoh Aficio 1113 (Similar to MP1500 and MP1600) With SC901 Code
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Hello guys
    This Ricoh Aficio 1113 shows up the SC901 code after warming up
    the mechanic meter is connected and the fuses of the LVPS are all Ok.
    BICU maybe ?
    I'm running out of ideas,
    Any tip is welcomed.
    Thanks !
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
  • mongo
    • Jul 2009
    • 55
    Re: Ricoh Aficio 1113 (Similar to MP1500 and MP1600) With SC901 Code
    If you go to input check (5803 -035) can you see it as installed if not the counter or wiring is bad . If it install check 5113 and make sure its set to 0. Mongo
    • sandmanmac
      • 3981
      Originally posted by rapidocument
      Hello guys
      It may be connected....but does it work?
      I imagine the BICU is also connected.
      It's likely one or the other.
      Btw...I had an MP2000 a few months back, and it was a defective mechanical counter.
