Ricoh mp 2851
  • Transam1
    • May 2011
    • 48
    [Misc] Ricoh mp 2851
    I have a Ricoh mp2851 that has the dhcp set to off can t see where to turn it to on
    under interface settings access control range 1 range 3 and range 5 all have settings ass well mas access control 2 and 4 machine will not accept a print job and can not access machine through the browser says access denied
    can any one help can this be set back to factory settings.
    have tryed holding down the .& # keys for 10 seconds and resetting but has made no difference.
  • JonManchester
    Technician / Shop Manager
    • Aug 2013
    • 103
    Re: Ricoh mp 2851
    If the access range is 192.168.1.50 and the next range is 192.168.1.52, you can access the machine through the browser with 192.168.1.51, hope this helps.
    Merry Christmas.
    Live for something or die for nothing.
      • 37556
      Re: Ricoh mp 2851
      Only devices within one of the access ranges can access the device. If you cannot get into WIM, try using telenet or use SP5801-011. SP 5801-011 will clear all network settings.
      Check that SP 5985-001 must be set to 1 for network functions to work properly.
