MPC 2050 Postscript card location?
  • copyaction
    • Oct 2007
    • 985
    Customer wants to add the post script card and I didn't know where to tell him it gets installed, can anyone pass that along to me, Thanks
  • cadillac2
    • Oct 2015
    • 42
    Re: MPC 2050 Postscript card location?
    sd card slot 2
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3945
      Upper SD slot.
      It's in the product support guide and service manual.
      • cadillac2
        • Oct 2015
        • 42
        sd card slot 1 (upper). the customer may have to unscrew the metal cover
        • copyaction
          • Oct 2007
          • 985
          Ever had one of those days?
          I was looking right at it
            • 36796
            If there are already 2 SD cards installed, you may need to move the contents of the current top card to the PS3 card, follow instructions in service manual. If the SD card in the bottom slot is JAVA, you need to stop JAVA before removing the JAVA card to prevent the possibility of cratering the controller board.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3945
              C
              Correct!
              The PostScript and Java card cannot be moved due to licensing.
              They can, however, have other apps moved onto them.
              Work of caution: Not sure if it pertains to all models, but the machine will allow you to move PostScript and Java. The process will ruin them, making it necessary to buy new ones.
              We had a tech attempt to move the PostScript card contents on an MP C6001. and it roached the card.
              That was a VERY expensive lesson.
