MP2851 strange black marks duplex only, odd pages, it gets even weirder
  • copyaction
    • Oct 2007
    • 991
    OK customer has mp2851 running 11x8 1/2 duplex black line border around pages.
    Only odd number pages getting these weird shadows right at one of the black lines.
    Only happens on 11x8 1/2, not 8 1/2x11.
    Only happens on duplex.
    Only on odd number pages on left side.
    happens from adf or glass.
    If I turn originals marks move to right side.
    Any other pages without black borders run fine duplex no marks any pages.
    Replaced drum unit and fuser and problem remained
    I was able to run the job 8 1/2 x 11 for them but obviously they want to know why it can't run the other way
    see sample:
    sample.pdf
  • Iowatech
    Not a service manager
    • 3930
    Re: MP2851 strange black marks duplex only, odd pages, it gets even weirder
    Um, this is just a guess, but are the paper guides leading leading from the ITB to the fuser clean? Sometimes toner builds up on them, and if the paper has curled more from going through the fuser the first time it might pick up some toner on the leading edge of side two of duplex copies there. Depending on the grain of the paper that is being used, it might curl more when being fed LEF, so if the paper is being fed SEF those marks wouldn't show up.
    Although, when I've seen toner buildup in that area it is usually purple or tan, so this is kind of unlikely. Sorry.
    • copyaction
      • Oct 2007
      • 991
      This model is b&w
      and the marks show up on the same line but in different position and sometimes only one mark.
        • 37484
        Is the paper being fed long edge first,LEF, or Short edge first, SEF?
        • mongo
          • Jul 2009
          • 55
          If it does it only on duplex or is it on the bottom side of regular copies. I would replace the transfer roller and turn on transfer roller cleaning (sp 2996 I think) to see if its goes away. Mongo
          • copyaction
            • Oct 2007
            • 991
            11 inch first.
            if I feed 8 1/2 inch first no marks anywhere.
            funny thing was if I rotated the originals 180 degrees the marks moved from the left side of the page to the right side almost as if it is happening during the scan.
            I can certainly try another transfer roller, the machine does only have 69K on it.
            • TonerMunkeh
              Professional Moron
              • 3865
              At 69k it is due for a PCU rebuild.
              Hit it.
              • Gift
                • Mar 2011
                • 2459
                Originally posted by copyaction
                11 inch first.
                You can try pc print or internal prints (i.e. SMC lists) to determine if it's a scan related issue or not.
                • copyaction
                  • Oct 2007
                  • 991
                  replaced with new type 1027 pcu, both do exactly the same.
                  • copyaction
                    • Oct 2007
                    • 991
                    I will see if customer can duplex print it from her computer.
                    No other originals or test pages that I ran, duplexed, would duplicate the problem. Only this with the black border lines does it.
                    I ran blank pages, counter sheets, plain text pages, all duplexed and set exposure all the way dark to see if I could see a trace of it and nothing, only the pages with the black border lines.
                    • copyaction
                      • Oct 2007
                      • 991
                      tried new transfer roller today, no luck.
                      • Iowatech
                        • 3930
                        This model is b&w
                        OOPS! My bad, sorry about that!
