Errorcodes495 and 101 appears.
I checed and cleaned toner recycling in drum unit, pump,replaced pump motor, checked and cleaned toner supply tube with no results. Also i noticed if imake one by one copies doesn't apper sc 495 (i made about 100 one by one copies).
Also sc 101 appears i replaced scanner sensor, checked cables are ok, lamp lights ok
Any idea.
Copies has made only 250 copies.
Any idea.
