Ricoh Aficio 1035 SC-350 Error Code
  • tcypy1961
    • 773
    While working on this copier I noticed that has told me to CRAM and change the developer. Well the developer has been changed, but I'm not sure what CRAM means. So my question is, what does CRAM mean? Could it mean to clear the RAM? And if so, I will execute SP5801? Thank you for any help given.
  • sandmanmac
    • 3981
    Re: Ricoh Aficio 1035 SC-350 Error Code
    Honestly, I have no idea what that term means, but why begin an entirely new thread, when you posted this issue 2+ weeks ago?
    http://www.copytechnet.com/forums/ri...ht=#post499887
    Along with "cram" , there is also a strong indication of Defective BICU, Controller, HVU, Firmware, etc. At 16 years old, I really wouldn't be surprised.
    Can we PLEASE move on??
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Don't CRAM it, shit can it!!!!!!!!!!!!!!!! but really for the sc350, clean it and pm it fully with a new OEM drum!!!!!!!!!!!!!! The drum is only rated for 150K. as for my self I would shit can it first!!!
      Perfect time for an upgrade sale....................................
      Mystic Crystal Revelations
      • bob marley
        • Jan 2012
        • 1339
        Possible cause
        ID sensor defective
        ID sensor connector defective
        Poor ID sensor connector connection
        I/O board (IOB) defective
        High voltage supply board defective
        ID sensor dirty
        Defect at ID sensor pattern writing area of the drum
        Live for yourself and you will live in vain. Live for others, and you will live again
          • 37481
          CRAMusually refers to the on board CMOS RAM on the fax option.
          • Herostrat
            • Oct 2012
            • 220
            Af 1035 is quite old so I'd guess that it had it's fair share of PM's...it could be that drum is withing PM range,I think u may have problem with old Cleaning Entrance Seal,it's placed opposite of drum cleaning blade preventing waste toner to spill out.
            After a while it will bent inward and allow toner to drop out on ID sensor generating SC 350 or SC352,common thing on older machines.
            It's a bitch to have to work on old machines...ones that belong in the trash can
            Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
            • andrewdecruz
              • Jul 2009
              • 74
              Sorry to say this, but in "human age" terms this model should be about 150 years old. It has certainly enjoyed it's fair share of the limelight during it's heyday. And yes, as was advise by most of the threads here, it should be put to sleep.
