Ricoh SP C311 sc542
  • 1stcavvet
    • Apr 2015
    • 231
    [Error Code] Ricoh SP C311 sc542
    I need to reset this error code. tried holding down up and down arrows for 5 sec then press enter/# key. Can't get in. I seem to remember there was something weird about this machine I had this problem about a year and a half ago. The other entry I found was hold down the escape and the online keys while you turn it on, there is no online key. I have to be missing something,anyone got a way in ??? Maybe a key on the keyboard is failing. HELP thank you
    • 37490
    Re: Ricoh SP C311 sc542
    This model uses SOM (Smart Organizing Monitor). It is on the driver disk or you can download it from Ricoh. You obviously do not have a service manual or you have known this. Either that or you did not take the time to read it.
