Ricoh naming convention?
  • Counsel
    • Aug 2011
    • 529
    #31
    Re: Ricoh naming convention?
    A lot of our older machines were labeled as gestetner, then we switched to the lanier labels around the ld016 time, so i only know of them as a gest or lanier number, on the forums i still have to cross reference the ricoh model to the lanier model so i know what machine people are talking about. It has gotten easier lately with the model numbers going standard across the labels.
      • 37490
      #32
      Personally I would rather they use the Product Code. Older machine problems are easier to look up in Gooses Guide. Attached is a copy of Gooses Guide that has a cross reference for the older models. You might find it helpful.
      GG_Oct_2014.zip
      • hussam
        Engineer
        • May 2014
        • 11
        #33
        Originally posted by Lagonda
        Does anybody know if the Ricoh EDP code for consumables is the same across their brand range? We're 90% Ricoh here in Oz but occasionally you run into a Lanier and I get asked if the toners are interchangeable.
        - The old Ricoh EDP codes for consumables used to be different across Ricoh & NRG brand range.
        - The new Ricoh EDP codes for consumables are currently the same across Ricoh & NRG brand range.
        - The Ricoh EDP codes are not the same across Ricoh, Lanier, Savin & Infotec brand range.
        - All toners are interchangeable across all of these brands.
          • 37490
          #34
          In the US, they have started only accepting orders for the Ricoh EDP. Lanier, Savin other RFG brand EDPs no longer are allowed.
