Ricoh Aficio MP C4500
  • aoab50
    • Nov 2014
    • 9
    There are color strips on the page when I print first, these stripes fade away after several prints, but it comes again after I restart or when I stop printing for a while.
    I've attached an example that shows magenta and yellow strips but other in other prints there is cyan strip also.
    I haven't done anything yet and I don't know the cause except the electricity current is weak and cuts off several times a day
  • skynetto
    • Sep 2012
    • 257
    Re: Ricoh Aficio MP C4500
    Replace transfer belt cleaning unit.
      • 37533
      Drum unit well past recommended replacement page count.
      • hossam
        • Aug 2010
        • 70
        Looks like magenta and yellow drum unit problem
        Sent from my GT-I9300 using Tapatalk
        • bob marley
          • Jan 2012
          • 1339
          seems u need to replace magenta and yellow drum units
          Live for yourself and you will live in vain. Live for others, and you will live again
          • teebee1234
            • Jul 2008
            • 1670
            What skynetto said, transfer belt cleaning blade.
            • Herostrat
              • Oct 2012
              • 220
              That machine's transfer belt cleaning blade got tired of cleaning calibration patterns from transfer belt,there should be a blue collored smudge also but I think there's no pattern to it,it happens random.
              And I beleve that's a copy so optics needs some cleaning,there's a thin blue line on the lower half.
              Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
              • aoab50
                • Nov 2014
                • 9
                Thanks to you all.
                I don't think the problem is from drum units because like I said before in other prints there is the three strips, cyan magenta and yellow and this problem happened all happened at once.
                Do you think I should replace the entire cleaning unit or only the cleaning blade.
                thanks for your answers again.
                • Herostrat
                  • Oct 2012
                  • 220
                  I'm not realy sure there is OEM cleaning blade as spare part unless you find some "For use" parts.
                  Go with the Cleaning unit it's not very expensive and it's durable...it's PM life is around 160k pages.
                    • 37533
                    Originally posted by aoab50
                    Thanks to you all.
                    J usually replace the entire cleaning unit. However, I do not believe that it will completely correct the problem. The ID pattern would be a series of squares close to both edges of the paper and down the middle. The pattern that I am seeing is usually from a dirty charge roller or from toner building up between the cleaning blade and the lube spreader blade as the result of a worn lube bar.
                      • 37533
                      Blade and brush roller were available from Ricoh. After time spent replacing them the cost savings were lost.
