mp7500 weird lines
  • vargue
    • Oct 2011
    • 404
    [Misc] mp7500 weird lines
    hi fellas yesterday we worked in mp 7500 and after machine open sc126 .and on/off it's worked fine without any codes .then when make copy from scanner revealed short lines in all over paper .also from feeder the same thing. but i realized that it's happened when i make auto paper select but when i select paper tray it's may be show up or may be not it's ghost thread.i have
  • rthonpm
    • Aug 2007
    • 2860
    Re: mp7500 weird lines
    It almost sounds like you've got a memory issue. Try re-seating the RAM DIMMs on the controller and see if the problem goes away.
