MPC 3003
  • staffie man
    • Aug 2011
    • 59
    [Misc] MPC 3003
    Hi guys,hope you can help.I am about to set up this m/c with the fax option and need to set the rings to eight to answer,can anyone help with this procedure,thanks in advance.
  • Polarbear
    • Feb 2012
    • 1070
    Re: MPC 3003
    The magic book says:
    Ncu parameter:680576
    Number of rings until a call is detected
    Default: 1
    SP2-103-007 (parameter 06).
    The setting must not be zero.
    Press the GREEN button!!
    • Lucamp3003
      • Oct 2022
      • 8
      Re: MPC 3003
      Default: 1
      I resume this post, for help. I have the same problem, I should increase the number of rings. But I don't understand how to do it.
      Can someone help me?
      What should I press on the menu?
      TnX Luca
        • 37513
        Re: MPC 3003
        TnX Luca
        Start a new post grave robber.
        • Lucamp3003
          • Oct 2022
          • 8
          Re: MPC 3003
          ok
