Lanier 5635/AF1035 (B003) SC390
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    I have two or three of these left in my territory, so I don't do much to them and my service on them is pretty neglectful since I am trying to get the customers to upgrade the old rascals.
    I know what SC390 means, and I have read the previous threads concerning this code. But I have a question.
    I remember back when I serviced these machine on a regular basis, there was an SC code I would run across every now and then which would result from developer material getting way past its life cycle. I am thinking it was the SC390. I plan on going out to this call tomorrow and was wondering if I should take developer material with me ... or what else I might ought to take.
    Appreciate any help.
  • Fearless V K
    • 620
    Could be old developer, or a bad TD sensor, but I have gotten this from extremely dirty machines where toner/developer may be spilled inside, and from missing mylars inside the toner supply unit.
    A good cleaning usually goes a long way on those machines, but you should have a drum and developer ready if it needs them, these beasts don't go much beyond their rated replacement lifespan.
    Don't take that toner with me!
    • hjvol
      • Sep 2008
      • 25
      sc 390
      After servicing the machine and the problem presisits.....
      Go into sp modes and set the charge voltage to a set 1600v ,that solves the problem!!!
      • Baphomet
        Copier Technician
        • Aug 2008
        • 293
        Thanks guys. After going to the account and changing the developer material, cleaning it up, and doing the initializations ... the problem has not reoccurred. Appreciate the advice ... you guys ROCK!!!
        Thanks.
