Pro C 5100 - Excessive toner usage on Short runs
  • Sam Lay
    • Jun 2007
    • 5
    [Misc] Pro C 5100 - Excessive toner usage on Short runs
    Hi,
    We recently installed our first Pro C 5100 at a local and small printers who like all print shops use it for short and long runs. On the short runs in particular the machine seems to use up a large chunk of the toners bottles even when the coverage on the page is moderate. As these bottles are meant to do around 32k based on 8 % (A4 duplex) i wondered if anyone else is suffering with these machines burning through toner and also filling up waste toner bottles every other day?
    We have had a Ricoh Tech Spec out to check the machine over and all is ok but i keep asking myself can the machine be changed so it doesn't do as many checks on short runs etc.
    Any help would be appreciated!
  • houserman
    • Jan 2011
    • 27
    Re: Pro C 5100 - Excessive toner usage on Short runs
    Originally posted by Sam Lay
    Hi,
    Unfortunately this machine consume a lot of toner. I have 7 machines and the average toner consumption is about 12k with moderate coverage...so....there is nothing to do about it
      • 37557
      Try the settings that timytronic posted in post #23 of the following thread: http://www.copytechnet.com/forums/ri...ht=toner+yield
