MP 3352 SP, strange image issue
  • steele
    • May 2012
    • 48
    [Misc] MP 3352 SP, strange image issue
    Hi, machine is nearly brand new (10k printouts), for some time the are probmes with print quality. Printouts are full of stripes, and letters are shredded. The are even on SMC report! I upgraded all firmware (twice), replaced HDD, RAM, nvram, printer/scaner SD card, polygon but nothing changed. Could it be controller board?
  • skynetto
    • Sep 2012
    • 257
    Re: MP 3352 SP, strange image issue
    Check tranfer roller for worn gear. There is also a RTB (RD120056) for it wich deals with SC401.
    • steele
      • May 2012
      • 48
      It doesn't look to me like transfer roller problem, but like some kind of interferences during image processing. Stripes are too clear and regular, and not always the same. I also haven't noticed SC 401.
      • omorales
        • Mar 2015
        • 86
        Drum Shutter verifies this causes distortion when the sheet passes through the drum.
        • sandmanmac
          • 3981
          You replaced a lot of stuff, but there's no mention of a PCU. I've had a few very strange image issues over the years with this family of machine and replacing PCU resolved it.
            • 37533
            As to your question about the controller, yes. I wish they still had the Detailed Description section in the service manuals so you copuld look at the data path and see which boards data moved through.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              It DOES look like "noise" from the controller.
              • Polarbear
                • Feb 2012
                • 1070
                That looks like an IPU issue to me. Either that or RAM (which you said you replaced already). It is too regular and too clear to be mechanical in nature.
                Press the GREEN button!!
                • Gift
                  • Mar 2011
                  • 2459
                  Agree this "digitized-shreddered" error seems to be some corrupted data on the image path - perhaps memory dimm.
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    I've had this with dirty contacts on a controller dimm before
                    • copyaction
                      • Oct 2007
                      • 991
                      agree try, controller dimm
                      • logrady2331
                        • Feb 2011
                        • 301
                        drukarki?
                        • Counsel
                          • Aug 2011
                          • 529
                          Im not for sure but does controller only affect printed jobs, if you were to make a copy would the controller still interfere with the image as a measure of testing?
                            • 37533
                            On most models, the copy data is routed to the HDD through the controller board. That is why I like to look at the detailed description data path.
                            • bob marley
                              • Jan 2012
                              • 1339
                              seems to me like Dev or toner issue
                              Live for yourself and you will live in vain. Live for others, and you will live again
