MPC2500 cannot print color
  • alansoon73
    • Feb 2011
    • 15
    Hi,
    I have an Ricoh MP C2500 that cannot print color pictures but can copy/photostate color. Tried to change BICU board, install different printer drivers ( pcl6 universal print,universal driver v4.8, RPCS ) updatedIMG_20160130_081631394.jpg latest fIMG_20160130_081623361.jpgirmware but all still cannot solve the problem.
    Any enlightenment would be very much appreciated and thank you.
    • 37536
    Re: MPC2500 cannot print color
    Check User Authentication Management in either User Tolls or WIM. It could be turned on and only set to restrict color printing.
    • alansoon73
      • Feb 2011
      • 15
      Hi...user authentication management under printer is set as pc control and do no restrict...i tried both but still cant print color
        • 37536
        If you are not using user codes, it should be "OFF".
        • Polarbear
          • Feb 2012
          • 1070
          Hi,
          I have an Ricoh MP C2500 that cannot print color pictures but can copy/photostate color. Tried to change BICU board, install different printer drivers ( pcl6 universal print,universal driver v4.8, RPCS ) updated[ATTACH=CONFIG]31808[/ATTACH] latest f[ATTACH=CONFIG]31807[/ATTACH]irmware but all still cannot solve the problem.
          This may sound stupid, but there is a checkbox in the driver that reads "Print as greyscale" which will throw away all colours irrespective of other settings.
          Are you printing from more than one pc and getting the same results?
          Press the GREEN button!!
          • Elmo
            • Feb 2010
            • 541
            are you definatley using the MPC2500 Driver and NOT the MP2500 driver
            on the front page of the MPC driver in bottom left hand corner you can select color or black and white
            I Used To Live To Fix Things Now i Fix Things To Live
            • houserman
              • Jan 2011
              • 27
              Pay attention to the driver. MP C2500 and not MP 2500 (this one is a black and white machine)
