MP1100 with reocurring SC220
  • Herostrat
    • Oct 2012
    • 220
    This one is giving me trouble,It all started with throwing SC 240,SC 966 and it hawe SC990 and SC991 written in history,now it shows CS 220 ocasionaly.
    Tested it with LD,Polygon Motor,BCU and IOB from another machine and it still throws SC220 when powered on or when recovering from sleep mode,cycle off and on few times and it works.
    I'we entered numbers on the side of LD in SP2115 001~009 ,inspected and cleaned LASER SYNCHRONIZATION DETECTOR but still no luck.
    I'm starting to think it's related to drum quality even tho it's at 500k pages so far.
    Any thoughts on this?
  • Herostrat
    • Oct 2012
    • 220
    Re: MP1100 with reocurring SC220
    Seems like noone cares or noone knows.
    • NeoMatrix
      Senior Tech.
      • 3513
      Search MP1100 SC220
      ---------------------------------------- Goose Guide -------------------------------------------
      [ Aficio MP 9000 ][ Aficio MP 1100 ][ Aficio MP 1350 ] Sc220 Laser Synch Detect Board Defective
      [ Aficio MP 9000 ][ Aficio MP 1100 ][ Aficio MP 1350 ] Sc220 LD Unit
      [ Aficio MP 9000 ][ Aficio MP 1100 ][ Aficio MP 1350 ] Sc220 IPU Defective
      [ Aficio MP 9000 ][ Aficio MP 1100 ][ Aficio MP 1350 ] Sc220 BCU Defective
      [ Aficio MP 9000 ][ Aficio MP 1100 ][ Aficio MP 1350 ] Sc220 Laser Sync Error Suggest To Replace Both Front Door Switches
      [ Aficio MP 9000 ][ Aficio MP 1100 ][ Aficio MP 1350 ] Sc220 Laser Sync Detect Error Refer To Bulletin # 57 For Improved Reliability Of Imaging Unit..
      HTH
      • Herostrat
        • Oct 2012
        • 220
        Thanks Neo,I forgot about the switches,I only applied more pressure on them and forgot about replacing them.
        That Buliten might be usefull allso,thanks again.
        • Moza
          • 232
          x2 on door switches for SC220 but if your getting SC240/966 that is usually the LD unit
