Hi,
I have a strange problem with this machine and if you have any helpful suggestion that would be great.
When the paper is passing through the drum unit and transfer belt, there is a strange noise until the moment when the paper feed in the fixing unit. The copy is blured and reduced at the begining of the paper. The end of copy is ok.
It seems that transfer belt have lower speed then drum unit because when i remove the gear from transfer belt there is no noise anymore and seems that everything works fine.
Also , when i put the gear back and disconnect transfer bias from belt there is no noise at all but print is to light of course.
Neither of this two methods are not a solution and i can't figure out what is going on whit this machine.
btw. we try to replace several parts from another machine which is working fine like Drum unit, Fixing unit, Transfer belt, complete right door, all motors and gears . . .
Darko M.
Darko M.
