OSX cannot print on mpc2050
  • mdtrinh
    • Aug 2010
    • 68
    We have a very strange issue, cannot get the mac mini to print on mpc2050 at all. Copier data line is flashing endlessly , lock up the copier, power cycle is only way to reset it. Mac stated printing ... device connected message.
    - Postscript is installed on copier.
    - OSX 10.11, bonjour connect, mpc2050 postscript driver from Ricoh website (tried generic postscript driver, ip print, etc, no dice).
    - Print Safari web page, pdf file, doc file, same result.
    - Other windows 10 print as charm.
    - Same set up without any issue on different customer with mpc4000.
    Any idea?
    • 37508
    Re: OSX cannot print on mpc2050
    The Postscript drivers only work if the PS3 option is installed o the MP C2050. If PS3 is not installed, the only way to print is to use Apple's "Generic PCL" model. It allows you to print but did not support Color printing as of the last time I set one up.
    • mdtrinh
      • Aug 2010
      • 68
      Thank you for your input, i installed postscript module, SD slot, it did show up in print feature for configuration. i learnt it from set it up for mpc4000, which required for postscript driver, but it did not work for this set up, and could not figure out what is wrong with it.
        • 37508
        By Postscript driver do you mean the Postscript3 Driver ver 6.0.0 or the PS Driver for Universal Print ver 4.8.0.0. These drivers are for Windows X64 OS.
        MAC OSX 10.11 (OS X El Capitan) uses the PPD Installer ver 2.2.0.0.
        Ricoh has recently changed their driver download page. They used to show you a list of operating systems and you chose what you wanted to download for. The page now detects the OS of the computer you are using and presents you with the driver selection for that OS. If you want drivers for a different OS, scroll to the bottom of the screen and select OS from there.
        • mdtrinh
          • Aug 2010
          • 68
          We are using PPD-installer for MAC OS X 10.11 from ricoh-usa.com
          PPD Installer Ver.2.2.0.0 Released Date: 09/17/2014
          We also used generic postscript driver, still same result.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Windows may be printing OK, but which driver did you use, PostScript, or PCL?
            Make sure you test with PostScript from Windows to verify the PostScript option is working.
            We've had a few over the years where the PostScript card was either the wrong one for the machine, defective, or possibly improperly removed from another machine, so that te license ws broken.
            • mdtrinh
              • Aug 2010
              • 68
              Thanks for your input. It turned out to be a wrong Postscript card installed.
              • qbert69
                • Mar 2013
                • 1152
                You can always look at the OS X CUPS print log by typing into Safari's URL bar:
                localhost:631
                if the Safari CUPS GUI is not enabled, it will tell you how to enable it in Apple's Terminal Program.
                It just Pi$$es me off in this day and age that Ricoh *still* sees PostScript as an *option*!
                Even if it is an emulation of PostScript like HP does, Ricoh NEEDS to get their $hit together!
                I would buy (even though I work on Ricoh) a Kyocera any day OVER Ricoh JUST BECAUSE Kyocera's ease of set-up and the maintenance aspect--no rebuilding pcu's & fusers! (room for human error and technician is on the hook!) Kyocera Fusers, PCU's, etc. are assembled in a controlled factory environment, each part serialized and tracked, so if it fails before the part's lifespan is expired, it's under warranty and replaced.
                IMO, Ricoh has become the "Titanic" of the copier industry...they don't learn from their design mistakes, longevity of certain parts *suck* due to the material used to manufacture them.
                PS--I can't in true honesty recommend any Ricoh products, even though I work on them. The proof is in the fact that you will find MUCH fewer used Kyocera out on the market for resale due to the quality of design of the machines and the ease of maintaining them.
                REACH FOR THE STARS!!!
                Konica Minolta Planetariums!
                  • 37508
                  localhost:631
                  If Kyocera comes with PostScript pre-installed, then you are paying for it whether you need it or not. By the way, from what I have heard from IT personnel who work with OSX all the time, HP's Postscript emulation is a piece of crap. Ricoh does have HP's postscript emulation available for those who desire to use it. We haven't had any takers as of yet. On the newer models with PDF direct factory installed, the majority of Postscript is already installed, as a result the original Postscript SC card is no longer required to stay in the the SD slot. You can copy it to another card if you need to free up a slot.
                  As for maintenance, are you saying that every time a machine is due for maintenance you have to order the complete unit, Fusing/PCDU/etc?
                  • rthonpm
                    • Aug 2007
                    • 2858
                    Emulated PostScript, like HP's, often seems to cause more problems and frustrations than it ever does actually printing. Ricoh considers PostScript as an option because they're actually licensing the true PDL from Adobe, which doesn't come cheap. The difference between emulated and real PostScript shows up the first time you have a user that tries to print a PDF: half the time emulated PostScript ends up garbling half of the text or kills the images, or just does something stupid like never see the end command and keep printing until the machine is out of paper. Think of it the same way you would third party toner: it may fit in the slot, but it's going to cause you longer work in the end.
                    Mac users like to complain about the added expense of PostScript, but they're already paying a premium for everything else that connects to their precious device so they can deal with it.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      Keeping true PostScript as an option makes a huge difference when selling a fleet of machines to a large customer, sometimes even the smaller ones.
                      Corporate America does not need it, at least for the most part. (personally, I wouldn't be without it, but then again, I'm a Mac and Linux geek.)
                      Let's say it adds $500 to the cost of each machine. That's $50k on a 100 machine order.
                      That $50k can be a real deal breaker in competitive bids.
                        • 37508
                        I have also encountered techs who have installed the PostScript option and then download the PS3 driver for Windows and try to install it on OS X instead of the PPD installer for the specific OS X version the customer is using.
                        • KenB
                          Geek Extraordinaire
                          • Dec 2007
                          • 3944
                          That used to be one of my favorite tricks.
                          1. Install the Windoze version on a PC, and do a test print. It should not matter which version of Windoze is on the PC.
                          2. Note the name of the ppd file Windoze used ( on the test page). A ppd is a "PostScript Printer Definition").
                          3. Copy that file to a convenient location on the Mac.
                          4. Create a new printer on the Mac, pointing to the pod.
                          5. Configure the printer
                          6. As a bonus, open Safari ( no other browser will work), and go to "localhost:631". This will allow you to set more options, such as defaults, for example black and white vs. color as the default setting.
                          Years back, I used this trick quite often with Canon iR3200s with Fiery attached. For some reason, the ppd that came with the Windoze driver worked much better.
                          A ppd is not platforms specific, and should also work equally as well in Linux or UNIX.
