sc149 aficio gestegner 1802
  • eliaso
    • Jul 2014
    • 52
    [Error Code] sc149 aficio gestegner 1802
    hello
    I have this code on Gestegner aficio 1802
    sc 149
    thx in advance for help .
    This only have I found:
    God created mankind upright,
    but they have gone in search of many schemes.
  • eliaso
    • Jul 2014
    • 52
    Re: sc149 aficio gestegner 1802
    thanks friend that you trust me!!!!!!!!!!!!!!!! you took out my 4 points ,I am not joking, you must give me back my points
    today I was at the client ,I turned the copier ON , it worked normally , I keep it , after 15 minutes the client call me again and said that the error code sc 194 light again
    somebody can help?
      • 37553
      Is the error 149 that you specified in your first post or 194 as you specified in your second post? 149 does not exist in either the service manual or Goose's Guide.
      If it 194, white plate error. Could be dirty optics, bad lamp, bad lamp regulator, bad SBU or bad PSU.
      • eliaso
        • Jul 2014
        • 52
        • sandmanmac
          • 3983
          Originally posted by eliaso
          [ATTACH=CONFIG]31896[/ATTACH]
          ....And your point is?
          First of all, you initially provided the wrong SC code! That makes trying to help you VERY DIFFICULT!
          Then, Slimslob pointed out several things that could cause your actual problem - which are EXACTLY the causes you are now sending us a picture of!
          What do you want? Do something!
          • BlackMarket212
            Clean Scanner unit, celan lamp and mirror....maybe fix
            • eliaso
              • Jul 2014
              • 52
              this sc code flash on the screen of the copier and not from my mind
              I clean the laser head and the optical, they was so dirty, for now it work
              • Elmo
                • Feb 2010
                • 541
                This is all very basic stuff
                you should be cleaning the optics/glass and white plate
                on any visit to the machine
                especially if the machine is in a dusty environment
                I Used To Live To Fix Things Now i Fix Things To Live
                  • 37553
                  I am surprised that you hadn't been getting call about light copies.
