ricoh mpc 5501 fax board not detected...
  • n25an
    • Jul 2008
    • 1030
    ricoh mpc 5501 fax board installed... but not recognized...
    installed firmware... rebooted... same result...
    trying to get firmware just for fax board...
    in the meantime checking if there is anything that I have not done...
    doublechecked connections...
    reseated board...
    problem unchanged...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • LNorris
    • Sep 2008
    • 645
    Re: ricoh mpc 5501 fax board not detected...
    check the jumper on the fcu pcb to see if its in the on position
    • n25an
      • Jul 2008
      • 1030
      to verify little baby board that sits on fax board... has an off on three pin deal
      it has two positions off and on... its a three pin deal... its in the on position...
      no expanded memory on fax board...
      • LNorris
        • Sep 2008
        • 645
        yep that's it. I just reviewed the install instructions, nothing odd about them. if you go to user tools does the fax sp show?
        • n25an
          • Jul 2008
          • 1030
          it does not show up...
            • 37378
            1. Are you certain that you have the correct fax board?
            2. Is the small board fully seated on the main board?
            • Zeldaman
              • Mar 2011
              • 946
