Rebuilt the fuser. After a few minutes after boot up it threw a sc320 and I smelled the soul of the bicu board floating away. I checked fuser for any broke or pinched wires. Replaced laser unit and bicu and it blew another bicu immediately. Same component again Q22. Any idea why and any one know what component that it is. I can solder on a new one then pay for another board that some one else fixed. Thanks in advance Matt.
Ricoh 171
Tags: None
Re: Ricoh 171
Yikes! The magic smoke has been released?
The polygon mirror motor in the laser unit is the usual suspect for that error code, but you might want to check the wiring harness between that and the BICU too. Sounds like something got shorted to frame ground.
That machine has been around for a while, after all.Comment
Re: Ricoh 171
We got a similar symptom on the AF2018/MP2000 when the door loom is shorted against the frame.Press the GREEN button!!Comment
