Equitrac Configuration (MPC 3003sp)
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3945
    #16
    Re: Equitrac Configuration (MPC 3003sp)
    Originally posted by sharpmind
    The user can print in color while we are doing the testing for Equitrac. When you set the rules at "release all at log in", all documents whether is BW or color are released.
    Just wondering... Which print driver are you using?
    I always use the latest version of the Universal PCL 6 driver.
    Obviously, something changed between the trial and now, but what?
    I would still highly recommend going to PCC 4.23, and get rid of the 4.1x version, especially on on MFP this new.
    • Moza
      • 232
      #17
      This completely depends on what version of Equitrac you are using ?
      Anything above PCC 4.2.1 will not work on Equitrac 4 with an MP C3003. If you are using Equitrac 4 I would suggest you use something more stable like PCC 4.2.0
      Have you also set the device up with the correct pull queue ?
