RICOH MPC4000
  • omorales
    • Mar 2015
    • 86
    RICOH MPC4000
    Hello friends I wonder if someone had this problem.
    When connecting the equipment with open swicht, loading equipment, but at the time of closing the covers, it makes short electrical energy.
    I checked psu, wired aparantemente are fine.
  • Iowatech
    Not a service manager
    • 3930
    Re: RICOH MPC4000
    Well, while we will need more information to make a reasonably accurate response, you might review this to make sure that location has an adequate power supply for that machine:
    Power.pdf
      • 37529
      Re: RICOH MPC4000
      You might have a short in the fusing unit. Remove fusing unit to test.
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Re: RICOH MPC4000
        Turn the machine on with the front door and right door both open, to disengage the laser and fuser. If it still shorts check the PSU, then scanner, and finally all connectors you can find.
        Sometimes I have found a damaged right hand door wire that was making contact with the frame, so check those too.
        • turbojetboy
          • Aug 2009
          • 279
          Re: RICOH MPC4000
          It will almost certainly be the IH inverter board, behind cover to the right of the fuser assy.
          • omorales
            • Mar 2015
            • 86
            Re: RICOH MPC4000
            I was changed, plate and coil IH IH. The team started working again. thanks for the help
