Mp c4501 sc226 continuation...
  • SDtech619
    • Dec 2013
    • 40
    Hey all,
    So i thought i was done seeing this issue but apparently it has reared its ugly head like the poltergeist movie. I replaced the entire laser unit...I'm thinking firmware or BICU next. Suggestions? Thanks in advance!
  • tufbnme
    • 493
    Re: Mp c4501 sc226 continuation...
    Always update the firmware, this code (sc226) is for the Cyan, could possibly be BICU.
    226 D Laser synchronizing detection error: start position [C]: LD0
    The laser synchronizing detection signal for the start position of the LDB [K], [Y], [M], [C] is not output for two seconds after LDB unit turns on while the polygon motor is rotating normally.
    • Disconnected cable from the laser synchronizing detection unit or defective connection
    • Defective laser synchronizing detector
    • Defective LDB
    • Defective BICU
    1. Check the connectors.
    2. Replace the laser-synchronizing detector.
    3. Replace the LDB.
    4. Replace the BICU.
      • 37357
      From Goose's Guide:
      D088/D089 SC 226 Laser Sync detect error Cyan - replace laser assy #D0891851
      D088/D089 SC 226 Laser Sync detect error Cyan - check connections, laser to BICU
      D088/D089 SC 226 Laser Sync detect error Cyan - replace BICU
      I would start with the cable from the laser unit to the BICU. Less expensive than a new BICU.
      • SDtech619
        • Dec 2013
        • 40
        UPDATE 6/3/16
        So I ended up replacing the BICU...worked for a couple weeks annnnnnnd we are back to the same error. I will be trying to update firmware again and see if that fixes it. Tech support confidently advised it was the board...stay tuned. Thx for the replies!
