color print stop wiyh ricoh mpc 6000
  • khattab.al.masry
    • 212
    [Misc] color print stop wiyh ricoh mpc 6000
    Dear all:
    as i found in service manual for ricoh mpc that in service mode we can switch off printing specified color as we want by enable making "1" for specified color which we want.
    but when making enable for any color and get out of service mode and making printing nothing change.
    and make hint we turn off the machine and making printing also nothing change.
    and to make sure of our done we enter service mode again found the specified color enabled is as it is "0"
    which means nothing change.
    thanks in advance
  • MIKON
    • Jul 2015
    • 188
    Re: color print stop wiyh ricoh mpc 6000
    To enable single color sp5618 set to 0
    • Counsel
      • Aug 2011
      • 529
      After you push 1, you have to hit the # key to enter it. If you do not push # then it will only display 1 until you leave the menu and it will revert back to 0 as if nothing was entered.
