Ricoh FW770
  • tcypy1961
    • 773
    Ricoh FW770
    What would cause streaking from lead edge to trail edge yet not all the way across the page; the light black streaks become lighter when passing through a dark print;
    Thanks!!!
  • 1stcavvet
    • Apr 2015
    • 231
    Re: Ricoh FW770
    something hanging down after the drum but before the fuser maybe something on the front edge of the fuser assembly,Good luck
    • Iowatech
      Not a service manager
      • 3930
      Re: Ricoh FW770
      Is there any chance you could share a picture or two of the streaks?
      • tcypy1961
        • 773
        Re: Ricoh FW770
        Here's a sample from my post on the Ricoh FW770 the outer edges did not come out as dark in the picture
        • jdzr
          • 125
          Re: Ricoh FW770
          From the view I am getting it sure looks like a cleaning blade problem. If you can find the bracket for the cleaning blade assembly (release the levers to gain access like for jam removal) usually on the right side you can try to pick up the spring tension and then release it to see if this changes the appearance. You can also just look at the drum and you will probably find residue left on the drum if it is a cleaning problem.
          • Iowatech
            • 3930
            Re: Ricoh FW770
            I'd take this advice first.
            But I'd check the charge corona as well. If this machine uses the "write to black" process anyway.
