One scan doc per page??
  • Leebs14
    • Feb 2014
    • 457
    Hi all, I have a customer who wants to put 20 or so invoices in the doc feeder and scan them but rather than getting one multi page document they want a single scan document per single page scanned, ie. 20 pages in the feeder equals 20 single page scan docs.
    Can they do this on their Ricoh MPC?
  • copyaction
    • Oct 2007
    • 985
    Re: One scan doc per page??
    yes go to:
    scanner
    original feed type
    divide
    ok
    • sandmanmac
      • 3979
      Originally posted by copyaction
      yes go to:
      scanner
      original feed type
      divide
      ok
      Close (or maybe it's correct on newest models), but the machines I'm familiar with it's:
      scanner
      Send file type/name
      Single page PDF or Single page Tiff
      OK
      • copyaction
        • Oct 2007
        • 985
        scanner
        Send file type/name
        OK
        just did it yesterday on an MP2851 and still had the picture of the steps in my phone
        • sandmanmac
          • 3979
          well then, maybe it's the slightly newer machines that have changed it, because the MP C300 right in front of me, is done the way I described .
          Whatever the case....I think Leebs can figure it out from here
            • 37378
            scanner
            Send file type/name
            OK
            That is the only way I have seen. Usually use Original Feed Type for batch feeding of mixed single and double sided original to have no blank pages.
            • copyaction
              • Oct 2007
              • 985
              that was always the way I would set up in user tools for the default scan setting too.
              my customer wanted a way to divide a group of medical files into individual files without changing the default scan settings each time and "divide" worked for that.
              I thought that was what the OP was asking for, if he wants it to "default" to always being single pages then by all means set it up in user tools.
                • 37378
                [ATTACH=CONFIG]32110[/ATTACH]
                If they want it to default to that, after setting it in file type/name, press OK then press program - program default - program - yes. What ever the current setting were are now current.
                You might also want to change Scanner SP 1012-001 so that the destination is not dropped after each send.
