ricoh mp2851 recieving fax issue
  • barrylee66
    • Oct 2010
    • 37
    mp 2851 incoming faxes are coming from a remote fax server in another location . they don't come out unless you turn the machine off then on again, then they all come out. printing does not seem to be an issue. swapped controller board and it still does it. could this be a setting wrong. we just installed the machine. the little brother machine we replaced seemed to do this fine.
  • sandmanmac
    • 3964
    Re: ricoh mp2851 recieving fax issue
    Sounds to me like a reception setting.
    I haven't experimented with them, but maybe it's set to "store"
    If all else fails, there's no harm in doing a factory reset in fax SP mode and re-entering the few customer credentials
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3945
      Can it receive OK from other locations, or is the problem limited to the one fax server?
      I had an issue with a fax server about 2 years ago, where it could not send to a few locations, which all had the same unknown model receiving machines, or possibly fax servers. (It was a government agency.)
      Turned out to be a firmware update was needed on the modem in the fax server.'
      • Iowatech
        Not a service manager
        • 3930
        Do you have any info on the sending system you can share?
        It sounds a little like that is a non-standards based system.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3945
          At a different location, I had an MP C2050 that would rarely, if ever receive properly, and normally errored out.
          The Xerox we replaced always worked, and so did the the MP 1515 we tried on the same line.
          Turned out that the IP to analog card they had in their router kinda sucked.
          It just so happened that the C2050 was a bit pickier than the others.
          Once that card in the router got updated, all was OK.
          • Iowatech
            • 3930
            The original card must have been a cheap one.
            Back in the day, the fax language was only half as large as it is now, but fax capable units have always had the full amount of memory dedicated to the current commands. Good fax units zeroed out the unused memory, but cheap ones just left random garbage in the memory. It didn't cause problems then as that part of memory wasn't being used.
            Flash forward to the modern fax era, when manufacturers started adding commands to the formerly unused portion of the fax language memory. Modern fax units can detect the older ones with the zeroed out memory, but the garbage in the memory of the cheaper units sometimes interacts with the newer commands in unpredictable ways.
            If I hadn't moved since the transition, I'd show you the wall where I banged my head against because of this issue. The postman was able to deliver my mail through that hole.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3945
              Then throw Fax over IP into the mix. Admittedly, it takes some savvy to set the little varmints up, but even when set up correctly, still give us fits.
