MP-201 SC 120
  • ABS tect
    • Sep 2013
    • 511
    MP-201 SC 120
    On my MP-201 I only get an 120 code when doing reduce/enlarge on the glass. Normal copying is fine. Your thoughts?
  • StephenB
    • Aug 2015
    • 243
    Re: MP-201 SC 120
    You have a scanner home position error. When you say "other copies are fine" can you copy on the glass in 100% mode. So does it error out when the scanner moves ? If so this is where your problem is.
    It is difficult to see, but mirrors do come out of position when transporting.
    • ABS tect
      • Sep 2013
      • 511
      Re: MP-201 SC 120
      Right...when i make a copy on the glass in 100% mode it does just fine. No errors. So that makes me believe that the mirrors are not coming out of place while transporting.
