Ricoh 161 spf firmware update procedure ?
  • StephenB
    • Aug 2015
    • 244
    I have done firmware updates using SD cards on many Ricoh's, just create a romdata folder and put new fw in folder then insert sd card.
    I have the 161 updates for the sd card but when done like above, the Ricoh 161 does not go into " preparing firmware update" mode. It just goes to ready. I have tried both sd slots.
    What am I missing ?
    • 37513
    Re: Ricoh 161 spf firmware update procedure ?
    You might need to reformat the SD card. Use the Panasonic SD Card Format software.
    SD/SDHC/SDXC Memory Card Formatting Software | Download | SD Memory Card | Digital AV | Consumer Products | Support | Panasonic Global
    If the SD card is larger than 1GB you may need to get a smaller card or re partition your existing card to 1GB. Minitool partition wizard works nicely.
    MiniTool Partition Manager
    • sandmanmac
      • 3981
      The " Service" slot is the 3rd slot on those machines, and it's under a small metal cover above the other 2 slots
      • totoro
        • 568
        There is a sd card slot under a metal cover held on with 1 screw just above the usb and nic cable connectors. SM pg. 5-127
        Totoro
          • 37513
          Check the product code on the serial number plate. If it is either a B262 or B269, then it does not use SC card to update. It uses the older PCMCIA card. See Procedure for the B262 and B292 starting on page 5-130 in the service manual.
          • tufbnme
            • 493
            2nd the 3rd slot!
            • StephenB
              • Aug 2015
              • 244
              Originally posted by tufbnme
              2nd the 3rd slot!
              Thank you , Everyone ! thought it was something simple....3rd slot it was !
              • Wujek
                I have the same problem, I have tried 3 different sd card. It is possible to upgrade the network firmware in webadmin ?
                Regards
                Wujek
                • mikadonovan
                  • May 2008
                  • 2931
                  Yes, but you need to use the rfu version of the firmware.
                  NEVER ASSUME ANYTHING
                    • 37513
                    Regards
                    Wujek
                    Since the MP161 is old enough to have 3 SD slots, iit most likely does not support many if not all 2GB cards. Try using a 1GB card or better yet a 512MB card. If you don't or cannot get smaler SD cards, try using a software such as MiniTool Partition Wizard to create one on a larger card.
                    MiniTool Partition Wizard | Best partition magic alternative for Windows PC and Server
                    • StephenB
                      • Aug 2015
                      • 244
                      Just grab an SD card off a junker Ricoh. format it and load firmware with these. I have 5 or 6 pre-loaded with most common FW updates. never had a problem
