Lanier LD 520c
  • 88hawkfan
    • Jun 2014
    • 76
    Lanier LD 520c
    Another weird call, I was updating the firmware on a Lanier LD520c so they could scan to their new server. No big deal, easy fix and move on down the road. It's a damn Lanier, nothing goes as it should. I now have an SC 817 and the copier is deader than a door nail, tried to reload firmware again and same thing. Anybody have any suggestions? I'm guessing I either need a new NVRAM or maybe a new controller.
  • LNorris
    • Sep 2008
    • 645
    Re: Lanier LD 520c
    i would try reformatting hdd outside then reformat with machine first.
    • sandmanmac
      • 3981
      Re: Lanier LD 520c
      This is more of a question/curiosity, for those that will know the answer....
      Any chance this is one of the models that had the different controller boards due to the Manufacturing issue in Japan after the Tsunami? I remember reading on here years ago, that you could easily take out a controller with mismatched firmware on certain model(s).
        • 37532
        Re: Lanier LD 520c
        Which firmware modules did you update? SC 817 at power is an error reading the electronic file signature of the system kernel or the root system files of an option SD card. If there is any SD card options in the SD slots, other than JAVA, turn the machine on with the SD card removed. If it comes on minus the options on the SD card, the SD card is toast. You can order a replacement from parts. If it still does not start, download all firmware and update everything.
        Oh, by the way, if there was a JAVA card installed and you did not stop JAVA in user tools before removing it to update firmware, the controller is toast ans possibly the JAVA card.
        • Iowatech
          Not a service manager
          • 3930
          Re: Lanier LD 520c
          Good call, but I don't think that's the case. Best I can remember that was only an issue with some finisher boards. But that was a while ago.
          • 88hawkfan
            • Jun 2014
            • 76
            Re: Lanier LD 520c
            Initially update the engine, system, and web support so they could scan to Server 2012. When it went south, I tried every firmware on the TSRC webpage all to no avail. The only option is the DOSS, but the machine won't come on with or without the DOSS SD card. Upon further reading it looks like other people have had success on other models with the SD boot card. Anybody know if this machine has a card available? Looked at the parts manual and I've got nothing nor do I know what I'd be looking for.
              • 37532
              Re: Lanier LD 520c
              Are you saying that it does not have print/scan installed as on that model print/scan is on a SD card. It might be bad.
              • 88hawkfan
                • Jun 2014
                • 76
                Re: Lanier LD 520c
                The DOSS has everything transferred over on that card, but even taking the card out the copy function would still work without the print/scan card.
                  • 37532
                  Re: Lanier LD 520c
                  If the problem is a corrupted root file system on the SD card, removing the card will allow the copy function to work. If that is the case, you will need to order a new print/scan SD card and new DOSS card. These can be ordered from parts for much less than ordering from product. Just call Ricoh support and tell them what the problem is, that you identified to a corrupted print/scan SD card and that you have DOSS copies to that card. They may have you attempt to transfer the DOSS back to its original SD card.
                  • Tonerbomb
                    AutoMajical Resolutionist
                    • Feb 2005
                    • 2589
                    Re: Lanier LD 520c
                    Have you tried booting with a sd card with system firmware only on it, and dip sw #1 on the controller set to 1(on) ?????????????????
                    Mystic Crystal Revelations
                      • 37532
                      Re: Lanier LD 520c
                      Not an option with this model. Used to be used with the older machines that required the 4MB PCMCIA memory cards for updating when power was lost during update. SD card update usually recovers itself when power is returned as long as the SD card is left in the slot. If it does not restart the update, then a recovery SD card needs to be obtained from tech support, service manager if you work for a branch.
                      • MitchD
                        • Oct 2012
                        • 164
                        Re: Lanier LD 520c
                        I believe it was the ADF pcb's on the 6001's and like machines too. You have to be very careful updating FW on those not to brick them.
                        "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
