I have installed wrong firmware on Ricoh Aficio MP201spf.Now it shows SC 670. Is there a way to rollback the firmware or fix it ?
Ricoh Aficio MP 201spf wrong firmware
Re: Ricoh Aficio MP 201spf wrong firmware
What firmware did you install?It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it. -
You can try to install the correct firmware to remedy. If not, you are looking at controller/board replacement depending upon what you were updating.NEVER ASSUME ANYTHINGComment
Unfortunately not
Ricoh had to change chip suppliers at some point during manufacturing of that model
you must match the version of firmware to right board
A new engine board and firmware have been applied, as a different type of CPU had to be used on engine PCBs (BICUs) due to the earthquake and tsunami disaster in the Tohoku region of Japan on March 11, 2011.
IMPORTANT:
Do not install this firmware on boards that already contain an older version of the firmware. Older versions begin with "0" (Ex., v0.0.8:**).
If you install the old firmware on the new engine board by mistake, the new engine board will be damaged and will have to be replaced.I Used To Live To Fix Things Now i Fix Things To LiveComment
i read this treat and there is no hope i think... http://www.copytechnet.com/forums/ri...ighlight=SC670Comment
