I set one of these up to scan to folder and all is fine apart from it scans in Tiff format rather than PDF and I cannot see where to change it to PDF??
when you bring up the scanner, on the left side is a scan type button, select that. the tiff will be yellow (default), select multi-pdf. then on the upper right part of operation panel, there is a button marked "program" press that, then another screen will appear asking if you want to make settings default. select yes. i think it may have another question in there somewhere (not in front of a machine) that should set the pdf to default for you.
select scan button in screen select send file type/name select pdf ok then select programme button (white button next to yellow reset) then programme as default then programme then yes all done
I Used To Live To Fix Things Now i Fix Things To Live
