Ricoh Pro C901 fuser trouble
  • jdkeeley
    • Mar 2016
    • 14
    Re: Ricoh Pro C901 fuser trouble
    Originally posted by Tonerbomb
    there are 2 kits. kit A contains 4 pcu cleaning units, the ITB cleaning unit and the PTR assy and feed rollers and drum powder. The second kit contains a complete fuser with the web unit. All though you may be only running 11x17 when the fuser crashes your dead in the water. If you have the second fuser you drop it in and your running again. As for the .mqp file for the paper library, it's available through Ricoh's tsrc web site to dealers. That's also where firmware is.
    Thanks for your response Tonerbomb.
    At this point we don't have a tech available who can work on my machine, so I'm totally on my own here - as a new operator, I realize I know so little, so thank you again for your patience.
    I don't have access to the tsrc web site because I'm obviously not a dealer. Any idea how I get the .mqp file as I think the correct paper setting might be the solution the marks on the 80lb coverstock. Can you access and send it to me or is that against Ricoh rules?
    Where could I order the TCRU kits? Is there a good resource where I could find a decent used fuser?
    Is there anywhere I could access some training on the C901? With no tech in my vicinity I need to learn how to do some of the service myself.
    I am really grateful for this forum - it's such a great resource and I appreciate everyone's time in reading and responding to my posts. Thank you.
      • 37513
      Answer to both questions is either the dealer you purchased the hardware from or you nearest authorized dealer if you purchased used from someone who is not an authorized dealer.
      • jdkeeley
        • Mar 2016
        • 14
        Okay - I will try and contact Ricoh corporate again, although I haven't had much luck with them in the past. My local dealer only had one tech who could work on the C901 and he recently had a surgery and is out of commission. But I will certainly explore all the avenues I can.
        Thanks for your help slimslob!
          • 37513
          #19
          Your local dealer should still be able to sell you the TCRU kits and obtain the .mqp file.
          • athensome
            • Jun 2018
            • 3
            #20
            Hi guys. I have a couple questions to throw out too regarding the c901 fuser belts. First, somewhat the same as this thread, but we are rebuilding both our fusers, the first one we did and have been running for roughly 1000 impressions and the belt is already fraying on the edges. See the picture attached of the belt. This usually begins to happen when the belt is very near life end, but you will see this in every print 12x18 where solid color rolls over this mark.
            I rebuilt this fuser the same as I did before but have never seen this happen so quickly. Stocks run were all in paper catalog and nothing too crazy.
            Is there a way to tighten or loosen the pressure on the fuser belt to avoid these issues in the future? We run heavy cover stock 90% of the time and we will wear a belt out quicker than normal, but 1000 clicks is ridiculous! I have not finished rebuilding the other fuser yet, so wanted to get your opinions here before finishing it up.
            That leads to the second question: See my other posted pic of the second fuser we have. As I was putting it back together and gave a test spin before reassembling, I heard this which sounds like it is coming from this gear. None of the gear look worn out, but this gear seems to be jumping randomly and it has me concerned to put it in the machine. I have a short video too I can send you if you DM me.
            Any thoughts on both of these issues would be greatly appreciated!
            • athensome
              • Jun 2018
              • 3
              #21
              Here's a video link to the gear clicking sound I referenced in my second question
              • VNshrine
                • Dec 2017
                • 18
                #22
                you can help me c901
                • cxtqd
                  • Jan 2011
                  • 46
                  #23
                  Lỗi mực. Contact 0966568956
                  • davel
                    • Oct 2011
                    • 1107
                    #24
                    Try basic troubleshooting, how are the PM counters.
