A700 to A551
  • copytec
    • Aug 2025
    A700 to A551
    Hi guys,
    does anybody knows how machine can see speed of her work.
    Well: Aficio 700 , replace everything (PCU, Main bord, BICU, Scann, everything from Aficio 551) but it stays still A700 ! I count they have
    70ppm.
  • decimal
    • Aug 2006
    • 75
    Oh very simple ,it's front door...
    Just joke
    • paulg
      • Jun 2007
      • 278
      The nv ram i guess?
      Theres the plug and play
      5-907 Plug & Play (Brand Name and Production Name Setting)
      Selects the brand name and the production
      name for Windows 95 Plug & Play. This
      information is stored in the NVRAM. If the
      NVRAM is defective, these names should
      be registered again.
      times.
      Also the speed of the DF sp
      6-020 ADF Speed Adjustment
      When the customer points out noise form
      the ADF, use this to adjust the ADF speed
      to low.
      High speed:
      70 cpm
      Low Speed:
      55 cpm
      Some older models you had a dip switch on the Io board but if its come out of a AF551 i guess its set to 551 speed.
      • decimal
        • Aug 2006
        • 75
        Originally posted by copytec
        Hi guys,
        Well: Aficio 700 , replace everything (PCU, Main board, BICU, Scann, everything from Aficio 551) but it stays still A700 ! I count they have
        70ppm.
        The NVRAM is on BICU
        • copytec
          Yes, I know that
          I read the manual but what is "Original Type" key in 5-907?
          • paulg
            • Jun 2007
            • 278
            I know many techs would swap over the nv ram when swapping boards by instinct.
            Just a thought/suggestion.
