Ricoh 3353 - Printer Problems
  • printertnc
    • Jun 2015
    • 68
    English
    Hello everyone , I have a problem with a ricoh 3353 .
    The printer will print vertical lines in any press, both from Tray 1 or from Tray 2 , and Bypass .
    At first seeing the striped drum , I thought I'd replace it , but the problem persists .
    I checked everything , cleaned everything , even the rubber Paper transport .
    What could be the cause of this defect ?
    The only thing I changed was the wiper blade in the drum unit , but I doubt either one .
    Here the defect represented
    Grazie a tutti
    Thanks to Everyone
  • MBMCO
    • 7
    Re: Ricoh 3353 - Printer Problems
    Drum and or Fuser could cause this. Make a copy and then open the unit before the paper hits the drum and inspect the drum itself to see if there is toner on it anywhere these lines appear. If so it is the drum. Remove fuser and check hot roller. If it is scored it will cause similar issues.
    This is copies and printing I assume. Not an ADF or scan glass issue?
      • 37494
      When you replaced the drum, did you also install a new cleaning blade, charge roller and brush roller - charge cleaning?
      Quando si sostituisce il tamburo, ha anche installato una nuova lama di pulizia, carica rulli e pennello a rullo - pulizia carica?
      Translated with Google Translate
      • printertnc
        • Jun 2015
        • 68
