Ricoh MP C2800 Charge roller cleaning and part number?
  • hpexpert
    • Sep 2015
    • 10
    [Misc] Ricoh MP C2800 Charge roller cleaning and part number?
    Hi there,
    I am working on a Ricoh MP C2800. The problem is image quality. It is producing horizontal black lines on every print and there are cloudy black patches. The lines are about 29mm apart. I have taken the PCU apart and i can see horizontal cracks on the charge roller. My question is that if i clean the roller then would it resolve the issue? if yes then what is the best way to clean it? Also I need to know the part number for the charge roller. Hope someone can help.
    Thanks.
    • 37550
    Re: Ricoh MP C2800 Charge roller cleaning and part number?
    To my knowledge there is no replacement part for the charge rollers on Ricoh color machines. If the charge roller is indeed cracked, you need to replace the drum unit. If it is a color drum, there are a number of threads on modifications to use a Black drum to replace a color drum. If the charge roller is just dirty, the assembly holding the charge roller and cleaning roller can be removed from the bottom of the drum unit. On older style drum units, there are three tabs that lock into a flexible plastic piece. Release the tabs and rotate the unit up and lift it out. Be careful. If you break the tabs or the pivot pins, you will need to replace the entire drum unit. The newer units have two screws holding the end closest to the developer and three tabs. After removing the screws and releasing the tabs the unit lifts out. To clean the charge roller, rotate a sheet or two of paper between the charge roller and charge cleaning brush roller to keep the brush roller dry. Use a clean soft cloth or paper towel. Moisten it with water, do not over moisten. Wipe the roller from end to end, turning the roller slightly between pass. Once you have cleaned the entire roller surface, let it dry before removing the paper. When removing and reinstalling the charge assembly, do not bend the charge contact that is on one end. If the problem returns, or if the drum unit has over 80K on it replace the drum unit.
    • hpexpert
      • Sep 2015
      • 10
      Thanks a lot for your help. I have found a part AD02-7018 on the internet and according to the seller, this should fit c2800. I am not confident in purchasing that as this is the only web site with this info. what do you think?
      • Iowatech
        Not a service manager
        • 3930
        I don't see that machine listed here:
        Ricoh AD027018 (AD02-7018) Charge Roller, Genuine (J3236)
        so I wouldn't buy that roller if I were you. At least not for the MPC2800, anyway.
        (I still carry that roller as car stock, and I've never used it on anything but black and white machines.)
        • jonhiker
          • 661
          The part number, AD027018 is a charge roller for a black and white machine and will not fit that pcu. The charge roller is not available as a separate part.
            • 37550
            The models listed at the link location are all B/W. They are all contact type charge rollers. Most Ricoh color machines in the low to mid volume range use non-contact charge rollers. Material composition is completely different.
              • 37550
              Here is a YouTube video showing cleaning the charge roller. The start and end show removing and reinstall the roller assembly with the original style drum unit. I do not disassemble any further than that. As I said in my first, just roller paper between the charge roller and cleaning roller. Be careful trying to clean the charge cleaning roller. Many of them are made of a foam type material that is easily damaged.
              • hpexpert
                • Sep 2015
                • 10
                Many thanks for all the help. can I have the youtube video link please?
                • LNorris
                  • Sep 2008
                  • 645
                  i have used turtle wax to clean the charge rollers, its not a permanent fix, just long enough to get another one ordered to replace it.
                    • 37550
                    Hers is another attempt at posting YouTube video. If it doesn't work, just go to YouTube and search Ricoh cleaning charge roller for streaking.
                    • ruben
                      The New Guy
                      • Oct 2012
                      • 1203
                      Note: try not to remove all the coating on the roller, just cleaning gently is enough to remove most problems.
                      I personally use isopropyl alcohol to clean these charge rollers.
                      • hpexpert
                        • Sep 2015
                        • 10
                        Many Thanks, Just wondering if I can swap the charge roller with the yellow one as black is used most of the time?
                          • 37550
                          You have to take it out to swap it. You might as well clean it.Easier than taking the roller out of two units. Also, the first time the customer does any color at all you will be called back for streaks of yellow.
