MPc3502 tray #2 auto paper size detect
  • tufbnme
    • 493
    MPc3502. Tray # 2 will only show 8.5 x11 length wise. I cannot set the tray settings to auto detect because there is none within the user tools\tray settings. I have updated all the firmware, changed the drawer switch (just because) tried another tray assembly, no change.
    Any ideas?
  • Counsel
    • Aug 2011
    • 529
    Re: MPc3502 tray #2 auto paper size detect
    Under user tools / intitial settings / general features / see if "small paper size tray" is turned on for tray 2 if it is turn it off. This is only turned on when an envelope tray is installed which wont allow wide edge paper of that size.
    You might have to turn the machine off and back on if you do change it from on to off in order for it to take effect
    • tufbnme
      • 493
      That is exactly what it was. I have never seen that before. THANK YOU for the info.
      • Counsel
        • Aug 2011
        • 529
        No problem, glad it worked.
        • gstaylor
          • Mar 2009
          • 12
          This has just saved my bacon - perfect, thank you
          _____________________________________________
          Knowledge is knowing a tomato is a fruit.
          Wisdom is knowing not to put it in a fruit salad.
          sigpic
          www.inception.co.uk
          www.inception-store.co.uk
