Print in Different trays in the same job
  • tonnerboy
    • May 2011
    • 212
    Hi.
    I recently replace a Canon equipment for Ricoh and the with Canon I could send a job and choose the last page to be printed in a different tray.
    I do not have this option in the Ricoh driver.
    Can someone give me a hint?
    Thank you so much
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: Print in Different trays in the same job
    Which model Ricoh?
    Which driver?
    What application?
    • tonnerboy
      • May 2011
      • 212
      Originally posted by KenB
      Which model Ricoh?
      Which driver?
      What application?
      Hi.
      It is a MP 3554 and I am using PCL 6.
      I think that the application is not so important because it generate a PDF file. I just need the last page being sent to a different tray.
      This is what I have in Canon: Selecting a Paper Source
      Take a look on item 4. Specify the following options as needed.
      Setting Setting Value Description
      [Paper Selection] [Same Paper for All Pages] Feeds all the pages from the same paper source.
      [Different for First, Others, and Last] Paper can be selected for each page, such as for printing the front cover on a different type of paper.
      • sandmanmac
        • 3979
        I'm not sure you can do that with the PCL 6 driver, but I know you can, if you install the PCL5e driver instead
          • 37362
          Printing Preferences - Detailed Settings Tab - Paper. Your options are Main body of the document, front cover, back cover and chapter page. Chapter page lets you specify Print Mode (blank, 1 sided, 2 sided) and paper source (tray) for each page in the document. This is from the PCL6 driver for a MP C3001 that I downloaded a week age. Most current PCL 6 drivers should be the same. Also some word processing and publishing software allow you to configure within the file. I believe Fiery also allows this.
