I got a real head scratcher here
MP C3001 will NOT load yellow toner. So naturally I believe it is the toner pump, so i replace the toner pump, with a used one, and then a new one. Also gave it a brand new toner, new hose, and new pcu...nothing.
The toner is turning...but the toner pump just does not seem to be pumping...it is plugged in properly, i know that, but no toner is getting through the hose to the toner pump except a tiny bit which i believe is probably just from the force of the toner bottle turning and pushing the toner down ever so slowly.
I'm not getting any codes...i know in the past i have been able to run a machine with it completely missing a toner pump, just to see if it coded or wouldn't allow me and it was fine. So could it be that just the yellow toner pump is not getting power to it?
Any suggestions or help? I'm all out of ideas! Thanks!
