RICOH MP 4002 (J007)
  • omorales
    • Mar 2015
    • 86
    Hello friends someone had this problem with the ADF cuarquier help will be appreciated.
    • 37508
    Re: RICOH MP 4002 (J007)
    Original Jam 007 is an inverter sensor jam. The inverter sensor is not identified as such in the service manual. It is located in the original feed table assembly. It is the reflection sensor that is pointed down. The sensor could be dirty or bad. The harness could be bad or not fully connected.
    • omorales
      • Mar 2015
      • 86
      It could identify which is the sensor, the images?????
      • TonerMunkeh
        Professional Moron
        • 3865
        Sensors 3 and 18 on the second image both look into gaps on the reverse roller cover. One of those gaps has a felt patch in it that is a magnet for paper dust and spoofs the ADF into thinking there is paper there. Give the assembly a blast out with air.
        Hit it.
          • 37508
          Item D in the first image. Also item 18 in the second image, it is shown as a interrupter sensor but is actually a photo reflection sensor. It is positioned just after the inverter roller. 3 and 8 in the second image are before the inverter gate. You could also have an inverter gate that is sticking.
          • tufbnme
            • 493
            Remove the platen cover, then the transport assembly. The sensor patch is on the assembly. very common.
