MP6001 RADF GHOST JAM
  • wholesaler
    • Jun 2015
    • 20
    I have a ricoh 6001 the radf say jam j1 no jam some times it reset sometimes you cant i know these feeders can be a night mare any one seen this
  • keithxxiii
    Just a tech
    • Nov 2014
    • 469
    Re: MP6001 RADF GHOST JAM
    Have you checked all the DF sensors? There is a sensor wherein you have to remove 2 small screws, the front DF Cover, and a shoulder screw to access.
    Hope this helps.
    Aye! Cut the crap
      • 37491
      J1 is a jam found at power on (or when a door is closed). When the jam comes up, use ADF input check SP 6007 to see which jam sensor shows as being covered. Also check the cover open and feeder up sensors. If the machine does not see the cover being open and closed, it will not clear the jam.
