Ricoh SPC430DN - Dark Line in Magenta
  • mynameis
    • Jun 2015
    • 78
    [Misc] Ricoh SPC430DN - Dark Line in Magenta
    Hello.
    One of our Ricoh printers produces a dark line in feed direction in magenta colour, only. I use to print a full coverage 50% density magenta on A4 page.
    What i tried so far:
    - Change of PCDU
    - Cleaning of laser glass
    - Cleaning of laser mirrors, including polygon mirror
    - Installing new driver
    - Printing from different computers
    I exclude common parts like the transfer belt, as only magenta is producing this problem.
    Any ideas what else to check are very welcome.
  • mynameis
    • Jun 2015
    • 78
    Re: Ricoh SPC430DN - Dark Line in Magenta
    No ideas, anyone?
      • 37508
      The only things that I can think of that would only affect magenta are the magenta transfer roller in the ITB and a board or memory problem.
      • mynameis
        • Jun 2015
        • 78
        Just switched the complete transfer unit. Problem persits.
        Any dea, which board i should try to replace?
        I have some used 430 models around here, but i know that switching the borads can be a pain in the neck, because you have to keep the original nv-RAM chip, or change the serial number...confusing...
        • Polarbear
          • Feb 2012
          • 1070
          +1 on the transfer. Laser related issues would produce white lines.
          Transfer related issues would cause uneven density.
          When you switched the ITB and PCU did the line stay in the same place or did it move?
          Press the GREEN button!!
          • mynameis
            • Jun 2015
            • 78
            The line stayed perfectly in the same spot.
            • Iowatech
              Not a service manager
              • 3930
              Looks like the controller is the most likely suspect, although the laser signal travels from the controller through the bridge board and then to the laser unit, so the bridge board might be a candidate as well. Best I can tell, the bridge board is just behind the controller.
              • Lagonda
                • Aug 2008
                • 1649
                This model printer hates high density prints. The toner feed system just doesn't cope with shoveling large amounts of toner into the dev unit. The spiral in the feed pipe twist its self in knots and eventually locks solid. From memory the recommended toner coverage for this model is quite low and from past experience if you go to far over that level the pumps die. Suggest you look for the bulletin that explains it all.
                And just to cheer you up even further, the pumps are a pig to change!
                • mynameis
                  • Jun 2015
                  • 78
                  Yeah, i am aware of that. Changed about 100 of these hoppers myself. Best thing: Ricoh came with the follow up model 440, which is by far more expensive than the 430 was and all they changed: They made the display smaller. All other parts (really...all of them) stayed the same. We hoped they would fix the hopper problem by using stronger augers (made of metal or something..) but no.
                  Thanks for the heads up Lagonda, but it's a little off-topic.
                  By the way: I changed the controller and BCU, the line stays. Now going to change the bridge board, as suggested. If this doesn't fix the problem, i really don't know what could.
                  • Counsel
                    • Aug 2011
                    • 529
                    Just out of curiosity that's not a skyshot is it.
                    • Lagonda
                      • Aug 2008
                      • 1649
                      Thanks for the heads up Lagonda, but it's a little off-topic. .
                      Not really off topic, I was just looking at it from a different angle, The dark stripe was where the toner has been supplied correctly and the light parts is where the toner density is low. i.e the fault was in reverse.
                      It's a is the glass half full or half empty question.
                      • Counsel
                        • Aug 2011
                        • 529
                        nm i asked this, i was thinking of a different model.
                        • mynameis
                          • Jun 2015
                          • 78
                          So, i am at the end of ideas.
                          Changed:
                          PCDU
                          Transfer belt assy
                          Controller board
                          Bridge board
                          BCU board
                          Cleaned:
                          Laser glass
                          Laser mirrors
                          Line persists...
                          • Counsel
                            • Aug 2011
                            • 529
                            I know the PCU comes in a box of all 3 but we have had to replace single ones for problems right out of the box, it looks like a developer issue, we usually keep an opened box and use the PCUs 1 by 1 till we can return the defective units. You may have to replace the mag pcu again.
