MP 3350 PCU Unit Swap?
  • mdtrinh
    • Aug 2010
    • 68
    Is that possible to swap PCU unit from other good quality copier? (MP 2550/3350)
    I understand that we cannot do this with the legacy Aficio 3045 series copier.
  • rthonpm
    • Aug 2007
    • 2860
    Re: MP 3350 PCU Unit Swap?
    The 3350 is the successor to the 22/27 PPM machines which used a supply item PCU. You can use the old Type 1027 PCU in these, but you'll need to manually perform the dev initialisation.
    • mdtrinh
      • Aug 2010
      • 68
      Do you mean SP2801? (used developer carrier)
      • developer dumper
        • Oct 2008
        • 21
        those units can be used you will have to cut off the alignment pin on the pcu assy. for it to fit in the newer machines.
