Hi folks...I have a machine Im working on giving error to close right side door, I ohmed out the 2 switches, they are good...is there another switch that Im missing..?
thanks..Jaime
Indep. Copier Svc.
Are the actuators for those switches OK? Sometimes they get broken off by impatient users, and it can be hard for me at least to see that if I am in a hurry.
When opening the right door - there is a plastic pin (around an inch long, and half inch wide) about half way between the point where the right door meets the machine and the top release hinges on the front side of the duplex. This actuates the door switches when closed. As said before, these can be broken off by the customer.
