We have one that we have changed the web motor on as per the service manual but it has come back in anyone seen this thanks
mp7502 sc540-03
Re: mp7502 sc540-03
I've also had to replace the fusing wiring harness. On the rear side of the fuser tray, where the interface connector is, the wiring could get crimped when you remove/insert the fuser. That didn't fix the problem immediately. I had this problem once, replaced all PWB's associated with fusing, but didn't fix the problem until I replaced the fuser. Go figure.Comment
