MPC4000 DF JAM CODE 001
  • kannuki2
    • Feb 2012
    • 398
    Hi All,
    I've ran into a weird symptoms with a B802 or model DF3010 Document Feeder. It detects a "P" jam and displayed a Jam code 001 on screen will not go away.
    So Far, I've replaced new DF main board, all sensors (reg, exit, inverter, feed cover sensor). Input check show sensors are working great and I cleaned all the black felts at registration, exit sensor, and inverter sensor.
    I've attached a picture of the df electrical component for easy identification. df electrical.pdf
    • 37447
    Re: MPC4000 DF JAM CODE 001
    In a jam situation, if the machine does not see the necessary door being opened and closed, the jam message will not be cleared. With the DF it could be the top open sensor or the DF up sensor. If only one is seen opened and closed. Jam 001 will then be shown. 001 is a jam at power on or door closing.
    • kannuki2
      • Feb 2012
      • 398
      Thanks for your help, slimslob. Several of my senior techs suggested similar method. So, I ordered and replaced all sensors related to cover door and still the same issue. I've replaced Sensors 4, 6, 7, 14, 18, and 20 from the electrical component picture attached above.
      Another thing after I replaced the ADF board, the "P" jam disappear and when I lift the doc feeder up and put it down. It popped the "p" jam and I cannot reset it afterward. I don't know what I am missing here.
      • Polarbear
        • Feb 2012
        • 1070
        Kannuki
        I would suggest entering service mode and selecting option 6 (peripherals) and then performing the input checks (for sensors) and output checks for (switches) to confirm that the logic system is working. Physically trigger each sensor and switch to see that it changes from 1 to 0 or visa versa.
        Also have you checked that there are no punch debris in the paper path (some sensors need a black patch to be at neutral). The fact that it triggers when you close the cover tells me that it is seeing a sensor that is in a jam stats.
        Only other thing I can think is that something is broken or out of place. Check all the "flags" (mechanical triggers) to make sure that they are seated correctly.
        Press the GREEN button!!
          • 37447
          I don't see mention of the DF lifted off the glass. There are usually 2. One on the main frame for when a platen cover is used and one in the DF.
          Originally posted by Polarbear
          Kannuki
          When looking for what is causing a jam, look for a sensor that is showing as covered. Also check the original jam history to see where the last actually jam occurred.
          If all else fails, you may have to print the Non Defaults and network settings then do a memory clear. It is a drastic measure but I have had a couple of times where that was the only thing that would clear a jam code.
