Aficio MP2000 scanning problem on Windows 10
  • goldencup
    • Nov 2008
    • 366
    Hi, i have been installing printer and scanner (scan to smb) on Aficio MP2000 on various OS (XP, Windows 7, Windows 8, Windows 8.1) with no issue. I now install the printer on Windows 10 and works fine. My problem is scanner (scan to SMB). I use the same procedure from the previous OS but it is not working. Is there a procedure how to set up scan to SMB on Windows 10? Thank you very much.
  • laitang
    • Nov 2012
    • 627
    Re: Aficio MP2000 scanning problem on Windows 10
    U need NIB firmware v 6.19 ​b8675526k
    • keithxxiii
      Just a tech
      • Nov 2014
      • 469
      Try creating a standard account with full permissions to access the folder.
      Aye! Cut the crap
        • 37532
        Check the firewall settings. If the computer has McAfee installed you may have to contact McAfee for instructions as to how to keep it from blocking.
