af 1022
  • Gab
    • Aug 2015
    • 674
    af 1022
    I have noticed in several at these machines that paper jam occurs when it pulls paper from one cassete. When i check the paper in this cassete , paper is untouched (paper feed roller doesn't touch paper) . If a make a copy from the other cassete and then use again the previous cassete it works ok. I noticed in that casette that when paper cassete motor pulls up paper , it doesn't pulls it up all the way paper feed roller to touch but it has a gap 1 or2 mm .So when paper feed roller tries to pull the paper it doesn;t pulls it because it doesn;t touch it. When i make a copy from the other cassete paper cassete motor pulls up paper at these 1 or mm and it;s ok.
    Any idea how to fix it? It is very annoying and confuses customers.
  • Iowatech
    Not a service manager
    • 3930
    Re: af 1022
    Check the drive coupling from the machine to the cassette lift plate shaft. It can crack in the middle, which is kind of hard to see, but will cause the paper to not lift properly.
    Also, you might check the tray lift mechanics in the machine. On older machines like that I have seen the linking springs break. I have tried to reform them with varied but usually stupid results. If those springs ever break, replacing them, new or from another machine, is normally the best course of action.
    • copyaction
      • Oct 2007
      • 991
      Re: af 1022
      as mentioned the lift coupling gear cracked, lift springs weak or broken and make sure the paper tray end fence is not jammed up against the stack of paper.
      assuming of course you already replaced the feed roller and sep pad.
        • 37556
        Re: af 1022
        Every time I have had feed problems with these older dogs it has been a broken spring.
        • laitang
          • Nov 2012
          • 627
          Re: af 1022
          I solved it by replacing a stronger or shorter spring in tray lift mechanics.
          • mikadonovan
            • May 2008
            • 2931
            Re: af 1022
            Originally posted by copyaction
            lift springs weak or broken.
            This is what usually happens.
            NEVER ASSUME ANYTHING
